foot throttle and hand throttle
   / foot throttle and hand throttle #1
ket
Bronze Member
southern ohio
YM1802D
talk about a pain in adjustment.. when I got tractor foot throttle would stick. so I took it all apart and cleaned and put back to gether, foot throttle worked great,, but then the hand throttle would not stay in position, it would creep down when in use.. had to keep shift cover off and keep looseing and tightening till I got it right.. to bad it does just not just tighten up and its there..
   / foot throttle and hand throttle #2
You have an 1802d? I believe you can tighten down the pivot point of the hand throttle. I'm sure one of the experts will chime in here and be more specific.
yep you tighten the pivot point for the hand and foot throttle,, the trick is getting it right.. not to tight not to loose
wish there was a torq spec.
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
John Deere 51" Sweeper (A50774)
John Deere 51"...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2006 Mastercraft S-05-1142 (A50120)
2006 Mastercraft...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
