Foot throttle on the L4200,..do you use yours.
   / Foot throttle on the L4200,..do you use yours. #1
skyhook
Veteran Member
Canada Ontario
1996 Kubota L4200 GSTC,(sold) 1994 JCB 210S 4x4x4
On my 1996, I can only get the foot throttle up to 2000 rpm's,
then i have to switch to the arm lever.
Has anybody modified theirs to bring up the rpm's.
I'd like to just be able to use the foot throttle,
it would be one less "lever" to use.
Is this possible, or am I missing something here.:(
   / Foot throttle on the L4200,..do you use yours. #2
cable needs ajusted
   / Foot throttle on the L4200,..do you use yours. #3
Foot throttle should give you the same range as the hand lever.
Ok Gent's, thank's, that's good to know,
I'll take a closer look at this when the weather permits.
   / Foot throttle on the L4200,..do you use yours. #5
I don't know but on my grandfathers 1998 l4200 I can get it up to atleast 540 I'm pretty sure... I think if you look underneath the foot throttle you will find an adjustment screw try tightening it for more throttle, yes since the tractor is fully synchronized clutch with a loader I do use the foot throttle a lot hope this helps
Kubota 81
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
E-Z Trail 680 Head Cart (A50514)
E-Z Trail 680 Head...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
