3-Point Hitch ford 1310 wont raise when warmed up
   / ford 1310 wont raise when warmed up #1
jrod77
canton,tx
ford 1310
3 point wont raise when warmed up
   / ford 1310 wont raise when warmed up #2
My 1310 has 1600 hours. Bought new. The older it gets, the slower the hydraulics work. IIRC, it has the same hyd. pump as a 1210, so it started out at a disadvantage. Pressure gauge to a hose out back? Sorry, it's all I know. Good luck.
   / ford 1310 wont raise when warmed up #3
I'm thinking when hyd fluid gets warm, the viscosity decreases. Maybe you're low on your level? Or there could be a leak, allowing air into the hydraulic reservoir and aeration is what's causing your problem. Have you checked the level and color of your fluid when the tractor is warmed up? Have you tried bleeding the pump after it is warmed up?
   / ford 1310 wont raise when warmed up #4
Raise your 3PH to the top and then turn the drop speed knob to minimum/off. Next, shut off the engine and see if the 3PH drops. If it does, you need new seals in your lift cylinder. It's an easy job since the cylinder access is right under your seat.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
