Ford 1720 clutch pedal noise
   / Ford 1720 clutch pedal noise #1
mfkrp16
My 1720 has started making noise when the clutch pedal is let out. It does this in gear or not in gear. Depressed it makes no noise at all when let out it makes a knocking sound that seems like it comes from the front half of the tractor. I have looked underneath the tractor and nothing seems broke or out of place, but dont really know what to be specifically looking for. Any suggestions would be appreciated.
   / Ford 1720 clutch pedal noise #2
Maybe something to do with the transmission input shaft. How does the clutch act? Does it move the tractor like it should? Does it make the noise when the tractor is moving? TB
TB, The clutch does act like it should (no spongyness or slip) and it moves the tractor just fine. It just has the knocking noise whenever it is let out whether moving or not.
   / Ford 1720 clutch pedal noise #4
It may be the throw-out bearing. Check the clutch linkage adjustment, there should be free play at the top of the petal travel. In other words the throw-out bearing should completely disengage from the clutch and not touch or spin with the clutch.
Russell
   / Ford 1720 clutch pedal noise #5
ditto on what Russel said. You are contently riding the pressure plate finger with the throwout bearing. adjustment will correct it. I hope it did not permanently damaged the bearing to avoid a tractor split.
JC,
   / Ford 1720 clutch pedal noise #6
With any luck, it will be the throw bearing or the pressure plate. Make the adjustment as jones has suggested and try again. If the bearing is coming apart, or the pressure plate, you may feel some vibrations in the pedal, maybe not. You may feel something when you first push the pedal in when the bearing makes contact with the pressure plate. Maybe one of the arms on the pressure plate is broke or loose, or maybe the throw bearing fork or sleeve is worn. The pilot bearing could also be wore out allowing to much freeplay or wobble in the input shaft. All these things are the best news you could have. If the clutch turns out to be fine, I might lean towards the input shaft bearings, and or a broken tooth on the input shaft which wouldnt be good news:(. Hey JC, how much of the clutch can you see through the inspection hole? I seem to remember you posting a picture of yours at one time. TB
   / Ford 1720 clutch pedal noise #7
Hey TB,
I made a paper gage and trimmed it by a scissor to the thickness of disk plate. I then Used a vernier caliper and measured the thickness of the paper. I had more than plenty thickness left from the OEM thickness in the last 30 years of use. 3.2 millimeter left 0ut of 4.76 mm. I converted my reading to metric.
JC,
Thank you all. The nearest Ford dealer told me the same and I am hoping the linkage adjustment might correct this. I plan on adjusting the linkage and looking into the inspection hole this week when time permits. Hopefully the worst case scenario will not be it. Matt
I was curious to know how much free play should the clutch have to adjust the linkage correctly? My service manual does not give me an answer for this and I would like to adjust it right the first time to eliminate this possibility. Thanks Matt
   / Ford 1720 clutch pedal noise #10
Matt, my manual says 3/4" to 1 & 3/16". Have the same problem. Adjusted the clutch, wich works fine but the noise persists. Bought a pto chipper and cant get pto into gear. Not sure what to do.
Mark
2018 Ford F-550 Truck Altec AT40G 40FT Insulated Bucket Truck (A50323)
2018 Ford F-550...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
John Deere HSLD 2510H Nh3 Applicator (A50514)
John Deere HSLD...
Backhoe Bucket (A50515)
Backhoe Bucket...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
