Ford 1720 spindle seal leaking
   / Ford 1720 spindle seal leaking #1
Bedlam
Veteran Member
I have a Ford 1720 four wheel tractor, that has a leaking front spindle seal.
I know years ago I had done one side, and I can remember that it was as bad as I thought to replace.On the other hand I remember possibly thinking I dis-assembled more than I need to.LOL
If anyone has done this and could lend some ideas that would be appreciated. even a drawing or whatnot would sure put me at ease to attempt it again.. Thanks
allan
   / Ford 1720 spindle seal leaking #2
Support axle & remove wheel. Drain oil from hub housing. Support lower steering swivel or axle flange. Remove 4 bolts holding steering arm to swivel housing & leave the arm in place. Clean area of swivel seal. Remove support from axle flange & allow/persuade swivel housing & axle to drop off stationary upper half & dowel pin with steering arm. Allow 8" or so of clearance to allow vertical shaft to come down & out. Pull shaft out, pry out seal, clean bearing if needed. Reinstall bearing, install seal metal side up. Install shaft, reinstall lower swivel housing; I use a small floor jack to carefully seat the housing & new seal. Reinstall steering arm. Fill hub with 134D oil. Install wheel. Check oil in axle center section. Consider changing that oil and the oil in the opposite hub.
Thanks. Doesn't sound too bad to do. With all the snow i've been having , I might delay it a couple of months. thanks again I will print this out .LOl
Al
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2020 KENWORTH T680 (A52472)
2020 KENWORTH T680...
FAKE (A52472)
FAKE (A52472)
2012 Ram 1500 Crew Cab Pickup Truck (A50323)
2012 Ram 1500 Crew...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
