I have a ford 1900 4x4 it has 8x16 front lug tires on front, I checked and it should have 6x16 front tires. The dealer told me it would be the same width on both sizes of tires only height differance. The problem I have is there is only about 1/4 clearance between the side wall and the top knuckle pin plate. When I bought it the guy had the wheels turned around so I did not notice this. There was a bad bearing on one side which would let the tire rub on the knuckle when I turned the wheels around to narrow the front. So I fixed it and both side only have around 1/4 inch clearance. I checked and there is no play in the front bearings everything is tight. Does any one have the same issues with such a close fit? Not sure what to do other than turn wheels around and I do not really want to do that. Any ideas would be much appreciated. Thanks Joe
