Ford 1900 Power Steering Question
   / Ford 1900 Power Steering Question #1
HogSlayer6
MO/KS/AR
Case 930, Ford 1900 and 8N
I purchased a Ford 1900 4WD w/FEL and the Power Steering doesn't seem to work especially under a load. I can't find a manual for it around here but I have seen a couple of articles on the net about "power assisted steering" on the 1900 model. I have checked the hydraulic fluid level and it is ok. Is there a separate power steering unit or does it feed off the hydro system. If there is a separate unit where is it and how do I add fluid to it.
Jack
   / Ford 1900 Power Steering Question #2
Jack,
I'm not sure if I understand your problem, but it sounds similar to a situation I had with my MF.
I was using my loader moving brush to burnpiles not long after I got the tractor and found that if I lifted the load and started to move out the power steering wouldn't work immediately. I was operating at a pretty low RPM because the work wasn't heavy and I figured that was the best way to go. I was advised by service dept people to jack up my RPM's a few hundred and that corrected the "problem". Even if you're doing "light" work I don't think the oil flow will be sufficient with the engine idling. Hope this is your only problem! /forums/images/graemlins/smile.gif
Glenn
I don't know if I tried it at higher RPMs. I can't jump on the tractor and findout since its about 250 miles from here. I will try it at High Rev this weekend and see if it is any different.
Jack
   / Ford 1900 Power Steering Question #4
Sounds like priority valve problem unless you hear a relief valve whistling. Steering should get it's designated gpm (flow)before rest of system if it's like most hydrostatic steering systems. I suppose it could be possible to produce such a low flow that spool in valve wouldn't work properly. My steering works fine at idle, but pump produces 17gpm.
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2014 VOLVO VHD DAYCAB (INOPERABLE) (A50854)
2014 VOLVO VHD...
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
Super Material Lift MH1000 (A51039)
Super Material...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
