Ford 1920 Circuit board
   / Ford 1920 Circuit board #1
tomo91
Anyone know what the function of the printed circuit board on a ford 1920? Would it prevent the tractor from starting? I tested the key switch and neutral safety switch and they checkout ok.
   / Ford 1920 Circuit board #2
Does the starter crank engine? If so do you see smoke (color)?
No, won't crank at all and nothing is lit up all switches ohm out fine the only place where I have broken wires is behind the dashboard where the harness plugs in a mouse got at the wires there a few years ago and I repaired them best as i could. So I was wondering if that has anything to do with the starting circuit?
   / Ford 1920 Circuit board #4
Look for a fusible link on the starter. Many tractors have one at the post where the Pos battery cable attaches to the solenoid. Usually a red wire with a small white plastic shell. This is the point where all power to swithes and gauges originates. If this blows, nothing on the panel works, but if the battery and cables are good, you can jump the start terminal on the starter solenoid and it will crank.
DRUM OF MISC HOSE CLAMPS (A51244)
DRUM OF MISC HOSE...
Gehl 1870 Round Baler (A50514)
Gehl 1870 Round...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2011 BMW X5 xDrive35i AWD SUV (A50324)
2011 BMW X5...
Diamond 5' Heavy Duty Excavator Mower (LIKE NEW) (A50774)
Diamond 5' Heavy...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
