Ford 1920 Hydraulic issue
   / Ford 1920 Hydraulic issue #1
Steve L
AR
Ford 1920
I have a 1990 Ford model 1920 tractor and my Hydraulics just stopped working. I checked and added hydraulic fluid but it didn't help. Before I call for service, is there a couple of simple troubleshooting things I can check first? All Hydraulics are out (loader and rear 3 point) My plan was to change the filter and fluid out as my last ditch effort before making the call.
   / Ford 1920 Hydraulic issue #2
I can't link threads so the easiest way is to have you use google to search tractorbynet.com
In the google search box type "siter:www.tractorbynet.com 1920 hydraulics" without the quotes. That will pull up many treads you then can read to help you. If you have further questions try the ford/new holland forum sub forum own.operate and you will get more res ponces.
   / Ford 1920 Hydraulic issue #3
Steve,
Your hydraulic pump could have lost its prime if you've traversed a steep slope recently. The easiest way I've found to reprime the pump is to put the loader joystick into boom float position and allow the engine to run for a minute or so. With the engine still running, move the control lever back to neutral and see if the pump has primed. It may take a couple attempts.
Hope this helps.
Mark
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2022 McConnel TRAXX RC28 Remote Controlled Slope Mower (A51691)
2022 McConnel...
