Ford 2 bottom Scotch Plow
   / Ford 2 bottom Scotch Plow #1
dbworld
OK...apparently made a dumb purchase. Got a good deal on a Ford 2 bottom 3 point plow (not exactly sure what model). Was missing the "points" (shares) I figured...no problem....until I did research. Apparently it's a "scotch" plow....and from what I've found out, these are pretty much obsolete.
Probably should have done research BEFORE purchasing.
Anybody have any idea where I might purchase some points or shares for this type of plow? Other solutions?
   / Ford 2 bottom Scotch Plow #2
What do you think the reference to "scotch" means? Perhaps meaning cheap? or low end?
Didn't come with a rear furrow "wheel" ?
Painted up like a ferguson plow, but suspect that is close enough to being a Ford. :)
   / Ford 2 bottom Scotch Plow #3
Improvise; find some that are similar and then have a welder adapt your plow to accept them.:confused:
   / Ford 2 bottom Scotch Plow #4
Looks like a Ford 101 2-12 bottom plow. While not used for corporate farming, they are still used for small scale farming, gardens and food plots.
   / Ford 2 bottom Scotch Plow #5
If the Ford 101 shares will fit, a John Deere or New Holland dealer should be able to get them. They come in 12, 14, 16 inch lengths.
Also, they can be ordered from Tractor Supply - in person - not online.
Ag Supply has some too but the are more expensive than a John Deere dealer.
Problem is - you may have to buy them in lots of six.
   / Ford 2 bottom Scotch Plow #6
Looks exactly like the old Ford-Ferguson plows sitting in my barn (bought in 1952). New-Holland and/or Massey Ferguson dealer may have parts.
   / Ford 2 bottom Scotch Plow #7
Its not a Ford 101....Its most likely a Ferg. If it has a tail/furrow wheel, look to see which side the "cleaner" is located. If its at the back end of the furrow wheel and going forward, its a Ferg., if its at the front edge and pointing backwards its a Dearborn...As far as a scotch vs a stubble, vs a general use, you can use different shares if you want to change out the moldboard as well. You will find that whatever you use, it will most likely not be cheap...good luck. BobG in VA
Thanks for all the help.
First...I'm not sure what model it is? All I know there is "Ford" in raised letters on the main beam (between the two bolts facing in the pic.) I will look at it with tips here.
Second a scotch bottom plow, the shares (points) are like this.
They are supposed to be good at cutting sod.
The plow didn't come with any....and my research suggest they may be difficult to come by.
Unless I can find some new moldboards may be in order. Not such a great deal after all.....
   / Ford 2 bottom Scotch Plow #9
Those shares don't look anything like the Ford 101 shares. It also appears that the shins are one piece and part of the shares.
Not sure if the Ford 101 moldboards would mount correctly. How the frog is laid out would determine that. Attached is a photo that might help.
All I can say is good luck finding the parts. There are forges that make such things but they don't sell retail - only through tractor dealers. Going to a dealer would be your best bet.
   / Ford 2 bottom Scotch Plow #10
If you still have this plow,i know were you might get parts. place is called schrocks equipment in Oakland,MD 301-334-9060
2005 Ford F-150 Ext. Cab Pickup Truck (A46684)
2005 Ford F-150...
Big Tex 10PI 14ft. T/A Utility Trailer (A45336)
Big Tex 10PI 14ft...
Brenner 300 Gallon Skid Mounted Vacuum Tank (A45336)
Brenner 300 Gallon...
Rims and Tires (A46502)
Rims and Tires...
2025 Kivel 48in Forks and Frame Tractor Attachment (A44571)
2025 Kivel 48in...
Hilti TE 2000-AVR Electric Jack Hammer (A45336)
Hilti TE 2000-AVR...
