Ford 2120 tie rod ends
   / Ford 2120 tie rod ends #1
Gods Country
Pennsylvania
Yanmar sc2400 TLD, 1989 Ford 2120 with loader
Looks like my tie rod ends are officially whooped.
My tractor is a late 80's model. Not precisely sure.
The part numbers I am coming with are SBA334800631(LH) & 641(RH).
Just want to be sure the part numbers are good for 2120 Ford/NH tractors throughout the production. In the past when I went to Messicks I could look up the part numbers direct, but know I cannot seam to find the part prints for a 2120.
   / Ford 2120 tie rod ends #2
If you only need to replace the end assembly (ball joint connections), you can order SBA334800240 (LH) and 250(RH) from Messick's...probably less expensive.
Thanks, I see those numbers supersede the numbers I provided.
Although they seem to be out of stock.
I will have to give them a call.
2008 TAKEUCHI TL120 SKID STEER (A51246)
2008 TAKEUCHI...
(4) TRAILER GATE FRAMES (A51247)
(4) TRAILER GATE...
UNUSED CFG INDUSTRIAL QK16R EXCAVATOR (A51247)
UNUSED CFG...
JOHN DEERE S780 LOT IDENTIFIER 225 (A53084)
JOHN DEERE S780...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2023 JOHN DEERE 6R 145 LOT IDENTIFIER 169 (A53084)
2023 JOHN DEERE 6R...
