Ford 2600 Leak off tube, between injectors and fuel tank and injector pump to filter
   / Ford 2600 Leak off tube, between injectors and fuel tank and injector pump to filter #1
bjr
Veteran Member
Eastern WA
Jinma JM354
It's a diesel and I don't know what kind of tube this stuff is and where should I go to get it on a weekend. The local New Holland dealer thought maybe some kind of rubber hose but he'd have to order it. Need to get this tractor runnin' this weekend and right now the lawn/garden hose is looking to get shortened and re-purposed, but, it's way too big of diameter. I need something maybe 1/4" or 3/16" ID. Help me get some replacement hose/tube but I don't know what to ask for even. bjr
   / Ford 2600 Leak off tube, between injectors and fuel tank and injector pump to filter #3
G'day as Rick said 3/16 fuel hose is the go but if you are unable to get it and are desperate to get going then you can use clear plastic tubing BUT I would replace it as soon as you can get fuel hose, no longer than a week.
Jon
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
1999 Budweiser Beverage Trailer (A51572)
1999 Budweiser...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
