Ford 3910 Injector Pump
   / Ford 3910 Injector Pump #1
vfarms
Ford 3910
I have a Ford 3910 and the injector pump leaks fuel from the back side. Can the pump have new gaskets installed or does the pumb have to be replaced or rebuilt? Does anyone know the costs for new gaskets or replacement?
Thanks for your input.
   / Ford 3910 Injector Pump #2
I have a 3910 ford and I've taken the fuel pump off and it won't come out. What do I need to do
   / Ford 3910 Injector Pump #3
Have you unbolted the drive gear? In order to remove the pump you must first drain the coolant, remove the lower radiator hose and then remove a plate on the front of the timing cover to gain access to the gear. Remove the three bolts holding the gear to the pump's drive hub. The gear will remain in place while the pump is off.
2012 Kenworth W900 (HEAVY DUTY) (A52128)
2012 Kenworth W900...
2000 Ford F-650 TMA Attenuator Truck (A50323)
2000 Ford F-650...
2020 Kenworth T880 Tandem Axle Day Cab Road Tractor (A47384)
2020 Kenworth T880...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
