Ford 3930 oil pan removal
   / Ford 3930 oil pan removal #1
John3930
Kuna, Idaho
Ford 3930
I need to replace the oil pan gasket on ford 3930 tractor, do I have to drop front axle? Help
   / Ford 3930 oil pan removal #2
no you can role it forward by putting txo longer bolts in the front axle bolster where it bolts to the motor and role it forward about 3 inches
Thank you. Sounds more technical than I'm capable of. Do I need to unbolt from the motor to roll forward or is it independent of the bolts? Am I better served to take it to the shop or is it fairly doable? Thanks for your comments.
   / Ford 3930 oil pan removal #4
it pretty easy just undo the 4 bolts that holds the front end to the motor and replace the top two with some longer bolts and undo the hood and role forward it is easy
Thank you, much appreciated.
   / Ford 3930 oil pan removal #6
I need to replace my oil pan on my new holland tc30 I got the pan bolts out but the pan doesn’t just drop out what do I have to remove.
TORO Z MASTER 2000 ZERO TURN MOWER (A51247)
TORO Z MASTER 2000...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
300 GALLON PORTABLE FUEL TANK (A51247)
300 GALLON...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
RIDGID K-400 POWERED DRAIN CLEANER (A51248)
RIDGID K-400...
