BAG
Hello All,
About a year ago I purchased a Ford 4000 3 cyl diesel tractor. Based on the serial number, I believe it is a 1969 model. When I bought it all was well except the fuel pump leaked like a sieve. I found a post with instructions on how to replace the o-rings and got it done. I left the pump on the tractor and simply removed the top. I also replaced the fuel filter. After reassembling the pump, bleeding the filter and pump and bleeding two of the three lines at the pump, I cranked it up and it started. It seemed to run fine (no more leaks either) but the engine top speed seemed a little lower than I remembered. I shut it down and didn't restart it for several days. The next time I started it, the engine wouldn't rev much above idle speed. I've tried several times since with the same result. I was careful to note which holes the spring ends were in when I removed the spring and believe I reassembled it correctly. Because I didn't remove the pump from the tractor, I had to scrape the gasket off of the lower surface and try to catch the chips. My best guess is that a small piece of gasket or dirt fell into the pump and plugged something up. Does this sound plausible or should I be looking for another reason? I haven't cleaned the tank but the pump seems to be getting plenty of fuel. I cracked the bleeder bolt with the tractor running and got lots of fuel out without affecting the engine speed.
Any help would be greatly appreciated!
