I have a Ford 4000D. I cannot lift implements (10ft JD Disk) with the hyd cylinder.
the three-point lift works fine.
It appears there is only on one place to check for fill level for the hyd fluid and it is full.
I hooked hyd hose to another implement and the hose will jump but the implement will not lift.
Is this a dealer fix needed or something else to check?
than
k you
than
k you
