FORD 4400 TLB WITH 201 3CYL DIESEL - PISTON REPLACEMENT PROCEDURE
   / FORD 4400 TLB WITH 201 3CYL DIESEL - PISTON REPLACEMENT PROCEDURE #1
richwilshaw
romayor tx
ford 4400 tlb//ford 641 workmaster//yanmar ym1900
The piston rings on my 4400 are in desperate need of replacing. I have found kits for this engine for less than 400 bucks and with new oversized pistons, rings, sleeves and bearings etc.
The engine is a 201 diesel 3 cylinder.
Is this an in frame repair or does the engine need to be removed for this job. Anybody with experience I would love to hear from you.
I have had the head off when I first bought the tractor and that is easy enough, I am unsure of how to disconnect the piston rod from the crankshaft. Any help would be appreciated.
Thanks. Rich
   / FORD 4400 TLB WITH 201 3CYL DIESEL - PISTON REPLACEMENT PROCEDURE #2
I did an inframe on my 3000D 10 years ago. Usually the lower end on a diesel is what's worn out first. If let go long enough then the top goes too. My Ford had a different problem. The PO's operators removed the air filter hose to the intake manifold and operated the tractor in a very bad environment. The top end was so bad that you needed ether to start it in the summer in N. TX.....my first diesel purchase and I didn't know why one needs ether in the summer to start a diesel...but I know now. Grin
I went to the Ford dealer and asked who did machine work for them and was told of a machine shop close enough. I went to them with the head and not only did they do the head but sold me new pistons and rings plus inserts (bearings) for the rod to crankshaft interface.
Getting to the bottom is no biggie. Just drain the oil and unbolt it. Don't remember but you may need to undo the bolt holding the oil pump pickup screen to get it out and out of the way to get to all of the rod bolts once you drop the "pan". Nothing magic about them. Once you unbolt them and you pull the caps off, with the head off you just push them up and out of the cylinder. No sleeves on these engines which is great for me anyway. When you pull the caps off the rods pay attention to the "sleeves" under the caps and rods. These are your bearings and are to be replaced.....called "inserts".
Most times there is a ridge cut into the top of the cylinder where the upper ring stops moving up. Auto parts stores sell a tool that cuts that ridge out, may rent one, so that you can push the piston out. Just cut enough to get the piston out.
I checked a couple of mains and they were ok so I only replaced the rod bearings (inserts). Had I needed to replace the mains I would have had to pull the engine and I really didn't want to do all that working alone and all.
I measured the cylinders with a new ring (see next paragraph for how to do it) and they were close enough to not have to pull the engine and have it bored. I did put the cross hatch hone pattern on to cut the glaze on the cylinder walls so that the new rings will "seat"....wear in to fit the cylinder.
Go to your Ford dealer and get an after market repair manual. I don't have them in front of me (out in the shop) and it's cool and raining here today....N. TX. July 31 and it's cool and raining....whadda deal. I think the name is I&T and the number is somewhere around 40 or 41 as I recall. Tractor covered is on the front cover. Cost is about $25 and has all I needed to get her apart and back together.......I just googled "I and T manuals for Ford 4000" and found lots of entries. Seems Amazon has them too. You need them for torque specks if nothing else.
So if you have ever been into an engine and are mechanically inclined go for it. As I said I did mine about 10 years ago, didn't go back and tweak the valves or anything.....used Kopper Koat gasket coating for the head gasket, the engine is diesel with the associated high compression and have had zero problems. I guess I got it right.
HTH,
Mark
   / FORD 4400 TLB WITH 201 3CYL DIESEL - PISTON REPLACEMENT PROCEDURE #3
You can't install "sleeves" in that engine without boring the cylinders and pressing the sleeves in. Typically, but not always requires removing the engine and stripping the block bare to do a proper job. Kits for a 201 typically do not include "sleeves" because it is uncommon to install them in that engine. Removing the oil pan to access the bearings will require removing the front axle & bolster from the engine block.
Thank you texasmark and rickb. I appreciate the advice and I will be doing the repairs as soon as funds allow.
Please let me know if you think of anything else that will help. I just bought the repair manual and it is helpful but nothing beats hands on experience. Thanks again, Rich
   / FORD 4400 TLB WITH 201 3CYL DIESEL - PISTON REPLACEMENT PROCEDURE #5
It's been 10 years and I am a little fuzzy. In doing my inframe, I pulled off a couple of mains that I could reach without removing anything but the pan. I realize that if you have to do a low end on your engine to get to the front and rears quite a bit of the front end has to be removed to get at them. This is one reason I chose to not do the lowers. But as I said they had little wear, the tractor wasn't going to see that much service so I left them as they were. And after 10 years I don't regret the decision.
Good Luck
Mark
   / FORD 4400 TLB WITH 201 3CYL DIESEL - PISTON REPLACEMENT PROCEDURE #6
Ford engines were parent bore, if i recall. I.e. the block is disposable. worn liner means engine swap.
   / FORD 4400 TLB WITH 201 3CYL DIESEL - PISTON REPLACEMENT PROCEDURE #7
They ARE parent bore. That means NO sleeves. Until somebody bores the cylinders and installs dry sleeves as a service procedure.
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2014 Kia Optima Hybrid Sedan (A50324)
2014 Kia Optima...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
