Ford 4500 tlb no pushing power (clutch?)
   / Ford 4500 tlb no pushing power (clutch?) #1
Retire15
I have a 70's model 4500 tlb that was only using around 20% of it's power when I got it. I figured the clutch was going bad but could still get good use out the the backhoe. After changing the Transmission fluid I got a good increase in pushing power for a while but then a major loss. It will now barely climb the hills on my land.
My question is should I now start looking at repairing the cluth and at what expense?
OR
Should try filling with something besides the "combo" "universal" trans/hydro fluid that I put in it and just not use it for pushing and endloading and just live with it? Will another type of fluid make that big of a difference?
It is the 4 speed manual transmission
Thanks - Scott
   / Ford 4500 tlb no pushing power (clutch?) #2
You didn.t say if you have the forward and reverse mlever up near the steering column. If so then you have a torque convertter style transmission. Your problem will be in either the t. c. or in the forward and reverse clutch packs. If the tractor has good reversepower and no forwaard power then you have a clutch pack going bad. If weak all around then its the T.C.
_________________________________________________________
go to partspring.com for all parts and technical needs. Chat online with a service tech for answers to all your question. You can also e-mail questions also.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2006 Mastercraft S-05-1142 (A50120)
2006 Mastercraft...
2007 Case International MDX91 3pt Disc Mower (A50774)
2007 Case...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2008 Volkswagen Passat Passenger Car (A51694)
2008 Volkswagen...
CAT Skid Steer (A50322)
CAT Skid Steer...
