Jan 13, 2011 / FORD 4610 PTO #1 C challengr New member Joined Jan 13, 2011 Messages 1 Tractor FORD 4610 Is there a way to soften the hydraulic engagement of the PTO on a FORD 4610 with independent PTO, keep shearing rotary cutter shear pins.
Jan 13, 2011 / FORD 4610 PTO #2 Soundguy Old Timer Joined Mar 11, 2002 Messages 51,575 Location Central florida Tractor RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC lower engine rpm so that it is low but won't stall under pto load , and feather the control in over 2 seconds?.. tis what my 7610s manual says to do.. soundguy
Jan 13, 2011 / FORD 4610 PTO #3 RickB Super Star Member Joined Sep 18, 2000 Messages 15,143 Location Up the road from Dollar General WNC Tractor Just a Scag Soundguy said: lower engine rpm so that it is low but won't stall under pto load , and feather the control in over 2 seconds?.. tis what my 7610s manual says to do.. soundguy Click to expand... And if one is diligent, it works.
Jan 13, 2011 / FORD 4610 PTO #4 J Jbrink64 Gold Member Joined Aug 27, 2010 Messages 331 You can install a feathering stop. Part number E7NNC766AB. It has a stop bolt you push the lever up to, when the pto starts turning, you flex the lever past the bolt to the fully engaged position.
