Ford 4610 steering
   / Ford 4610 steering #1
beggar
Bronze Member
picayune,ms.
farmtra555-case1494-kubota M4050-F4610-MF285
I bought a ford 4610 at auction that came from a county road dept. I've found out there is 3 models of this tractor.One model is "highway". I think this might be mine as it does not turn sharp at all. Is there a way to fix this or modify it to turn like a regular tractor.any help thanks.
   / Ford 4610 steering #2
Post the actual model code and unit code of the tractor as found on the tag under the hinged portion of the hood or hand stamped in the clutch housing just behind the starter on the flat horizontal surface. And tell us whether it is 2WD or 4WD.
It's a 2 wheel drive. I can't get to the tractor but have this scratch down. DA314C also 4H275. I think the serial# is XC728032*
378574 (A51573)
378574 (A51573)
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
