Ford 4835 pto
   / Ford 4835 pto #1
CA AND
ford 4835
Ford 4835 pto will turn on and spin but has no power it will stall out with any applied load, electric engagement to turn on pto. Removed back cover took out all plates, fibers still have writing on them so do not seem to be worn much if any. can someone tell me what the clutch lockup pressure should be, I installed a gage on pressure line tee fitting at housing and recorded about 220 psi at about 1000 engine rpm.any ideas or sugggestions. Thanks CA AND.
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
12 Yard Rolloff Container (A51573)
12 Yard Rolloff...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2024 JOHN DEERE 3039R LOT NUMBER 165 (A53084)
2024 JOHN DEERE...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2010 L3 MEP-806B GENERATOR (A52576)
2010 L3 MEP-806B...
