Ford 5000 row crop
   / Ford 5000 row crop #1
aster
Ford 5000
Hi,
I bought a late 1960s Ford 5000 row crop tractor last spring in decent condition. I used it all last year and this spring. Suddenly it started to drip antifreeze out from the area of the bell housing. I thought maybe a frost plug. They look good. The head gasket also looks good. The tractor still runs ok except for this, so I am thinking maybe a cracked block? Anyone with ideas are sure appreciated. I use this tractor as my main tractor and sure miss it.
   / Ford 5000 row crop #2
The blocks that ford has built for years is very porous and they have had problems with leaks. You might have to do a split at the clutch and and pressurize the system to find it and after you do there are several things you could do depending on what you find.
   / Ford 5000 row crop #3
have u split the tractor and checked the freeze block in the back of the block behide the flywheel
Thanks I sure appreciate the advise
   / Ford 5000 row crop #5
I had a 6700 ford and a 188 massey leaking there that is the most likely cause if it had a cracked block it would be on the side of the block or in one of the cylinder walls
2016 Ram ProMaster City Van, VIN # ZFBERFAT5G6B45183 (A44391)
2016 Ram ProMaster...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A46877)
New Lewis Brothers...
2007 Chrysler Aspen (MPV), VIN # 1A8HW582X7F516547 (A44391)
2007 Chrysler...
2012 Isuzu NPR Truck, VIN # 54DB4W1B4CS803964 (A44391)
2012 Isuzu NPR...
2019 VOLVO VNL TANDEM AXLE SLEEPER (A43003)
2019 VOLVO VNL...
2016 Ford Taurus AWD Sedan (A44572)
2016 Ford Taurus...
