Ford 545C Industrial Tractor
   / Ford 545C Industrial Tractor #1
lac1957
El Dorado springs, MO
Ford 545C
We have this tractor, serial #A415924. The dealer we purchased it from says it is a 1982 model, but an online search told us it was only made from 88 to 90? Does anyone know what year it might actually be? We wrote down all the info we could still read from the tag in the tractor...............
Thanks!
   / Ford 545C Industrial Tractor #2
545 made to 83
545a from 84 to 88
545c 90-91
545d 93+
mind you this is tractor data date.. so take it with a grain of salt.. but what it illustrates is you need to pin down what revision your 545 actually is. if it was said to be an 82.. then the dealer thinks it's a straight 545
i didn't see any data from 88 to 90 betwixt a to c.. so not sure of a B model..
the finer points of these post 65 industrials will be territory more suited to user RickB or Whodat.
   / Ford 545C Industrial Tractor #3
A serial numbers started with the C series indicating they were built in Antwerp. Before that, they were built in Romeo, MI and the serial number started with a C. If the date code (the unit number on hood or the number on the transmission ledge above the starter with a number, letter, 2 numbers and possibly another letter) starts with a 2, then it is a 92.
There was no B model in the 445/545 models.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
LMC LOT NUMBER 275 (A53084)
LMC LOT NUMBER 275...
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
