ford 555 a
   / ford 555 a #1
mepowell1
ford 555 a
I need to know how do you change the transmision fluid and what kind of fluid do i use?
   / ford 555 a #2
..kind should be a utf equivalent to m2c134d type oil ( i guess unless she has a TC ).. as to where.. have to look at your manual.. or the online parts diagram to locate the trans drain.. that or rickb likely knows.
soundguy
   / ford 555 a #3
UTF 134D in everything but the engine..
   / ford 555 a #4
Remove the pipe plug at the bottom of the transmission housing to drain. Refill with NH 134D or an equivalent oil. Dipstick/filler is accessed through the foremost of two small access panels in the cab/platform floor. You will not drain the torque converter, so if you have badly contaminated oil, plan on two or maybe three changes. Don't forget to change the filter.
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
7022 (A50322)
7022 (A50322)
2016 Ford Explorer...
