Ford 555 bacjhoe won''t crank
   / Ford 555 bacjhoe won''t crank #1
farm8200
wilmore, PA
Ford 555
I have a Ford 555 backhoe (early 1980's) that I use probably once a month and when I tried to start it today, it would not turn over. The battery is relatively new and tested fine. There is nothing when I turn the switch (either direction). Does anyone know where the safety/neutral switch is located on this tractor and how I could check to see if that is the problem. any other suggestions would be welcome. Thanks
   / Ford 555 bacjhoe won''t crank #2
ford tractors are listed under "new holland"
new holland trying to get to the online parts catalog is to many clicks so i use place, i bought the 555c TLB from, for a quick link... Construction Equipment-Backhoes-Mini Excavators-Skid Steers-Pat Kelly-MO (center of page) parts catalog link direct to newhollands site. type in "ford 555" click search and pick year/model letter you have.
it costs like 150 plus bucks, but well worth getting the shop manual for the tractor. full break down of all parts in diagrams, and trouble shooting, and how to remove, test, and reinstall everything in step by step instructions.
some things to check, is make sure you have it out of gear, if you have shuttle shift make sure lever for it is in neutral, ((have had them DOH! moments)) more so when i did not realize i bumped something as i was setting down into the seat.
you might test the "starter relay" the 555c i have. all the relays were exact same model make. so i just took one out and swapped a couple times. and quickly found out i had a bad relay. ((all relays should be in the fuse box / panel. just make sure ya bring some reading glasses and damp towel and some dry towels to clean off all the dust and double check all the relays are same / make model before ya start swapping around and seeing if it will start.
   / Ford 555 bacjhoe won''t crank #3
I have a 555-A Ford Back/Hoe I need to replace the N/Switch on the transmission it has been going bad for some time a wiggle on the gear level was all took now it is almost total gone takes a long time to get it to work my arm gets tired -I have the new switch -How hard is it to get too with out tearing the machine down ?? Can I get to it down through the floor boards ?/ This machine has a full cab on it -I am almost afraid to shut it down as its cold and it is sitting outside -Please let me know if I can get to it -K
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
UNUSED CFG INDUSTRIAL KKT(A)27 STAND ON SKID STEER (A51247)
UNUSED CFG...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
UNUSED FUTURE FT850J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
