whitmire
- Joined
- Mar 31, 2015
- Messages
- 1
- Location
- Breckenridge, Texas
- Tractor
- Ford, John Deere, Massey Furgeson
Hello everyone. I am about to pull my hair out!!!! I have a Ford 555D Backhoe and I need to repair my loader lift cylinder but I can not figure out how to get it apart. It has a long wire/rod that goes from right below gland nut down into body of cylinder. The one I am trying to work on the rod is broke and the gland nut spins in both directions infinitely and the nut does not get looser or tighter and the small gap between the nut and cylinder body like it may be stripped. The other side is not leaking and the rod sticks through an opening in cylinder body which only allows the nut to move back and forth about a half inch (the oprning of the slot in body). It is the same tightness as the other side which I am able to move by hand with bucket resting on ground. with bucket suspended I can not move either. It is leaking out of the little slot in the body. FP417 is the repair kit and has the rod but I can not figure out how to get ram apart. I have been searching all over for some guidance and can find none so any help will be greatly appreciated.
Thanks,
Rick
Thanks,
Rick
