chimneyman
My Front-Loader "control valve" is stuck in the float position so I am anticipating that it will need rebuilding. (Tractor has a full "Sims cab" on it, blocking the view and access to the hydraulic control valve assembly.) I used my cell phone to get some pictures from many angles to help me start the removal procedure. I see the two bucket hydraulic lines, and I see the two boom hyd. lines coming out of the valve main block (four in total, all half inch dia.)... To my suprise I can only find one other ( 3/4"steel) line, which I assume is the supply from the Hydraulic Pump. I cannot find a return hydraulic-fluid line back to the sump/tank. I am a good mechanic but new to hydraulics. As I have tried to understand this system it has led me to a number of questions about this sytem specifically ..., but also to additional questions. First-Is there really only one supply line to my loader-control-valve? If so does this system work with a (fluid) bypass at the pump, which stays open until I call for pressure at the valve? Is this a closed or open center system?
Some additional info: the [744-Loader] hydraulic system appears to be a totally separate self contained system powered by a forward mounted 26GPM pump,..with the hyd-oil-supply held in the hollow part of the loader frame posts. On my 250C, is the 3-point hitch raise/lower system powered thru the transmission? Also I have noticed that my (loader) control-valve is mounted/standing vertically, where as the models 345 thru the 545D have the same control valve,.. but mounted horizontally (with the joy-stick linkages turned 90 degrees also.
LOVE this tractor--Truly a tank. Have operated some heavy iron, NewHlld JCB's JD's, but nothing is as fast or as powerful (deadlyin the wrong hands) as this little 250C. I would really appreciate some expert teaching here. Thanks in advance!
