Ford 861 Clutch Replacement
   / Ford 861 Clutch Replacement #1
pmgeiss
Corry, PA
JD 2720 (2012) and JD 5400 (1994), Ford 961 (1962), 861 (1958), 661 (1958), RK55 (2021)
Hello!
I am in the process of replacing the double clutch on my 1958 Ford 861 and am ready to put it back together. Can someone help me with the torque requirements for the flywheel to engine bolts, the clutch to flywheel bolts, and the main housing bolts?
Thanks in advance!
   / Ford 861 Clutch Replacement #2
Flywheel to crankshaft 75-85
Clutch to flywheel 12-16
No torque is specified for the block to transmission housing in the service manual, use a standard torque chart to determine the values.
  • Bolt Torque Values.pdf
This is precisely the information that I was looking for!
Thank you
2007 PARK SEPARATOR (A47001)
2007 PARK...
2006 JLG 2030ES 20ft Scissor Lift (A44571)
2006 JLG 2030ES...
2012 CIGARETTE RACING TEAM BOAT (A45677)
2012 CIGARETTE...
2025 Mini Excavator Ripper Attachment (A45336)
2025 Mini...
1999 FORD SUPER DUTY F350 XLT DUALLY PICK UP TRUCK (A45677)
1999 FORD SUPER...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A45336)
2003 Big Tex 10PI...
