Ford 95 3930 rear amber lights
   / Ford 95 3930 rear amber lights #1
Happy Gilmore
Veteran Member
Southeastern, MA
Ford 5610 Ford 4630 Ford 3930 MFWD w/ 7310 loader Ford 3930 Kubota BX1500 Kubota RTV 900XT Kubota F2680E 72"RD Ford 4610 Kubota KX121-3
I need to replace the rear amber fender lights on my tractor. I'd like to stick with vertical 2 stud with original brackets. I'm thinking LED, can anyone recommend something good quality with close to the look of oem. The oem which was made by Signal-Stat is approx $120 just for the left side". Thanks
Any thoughts guys
   / Ford 95 3930 rear amber lights #3
Happy Gilmore,
Did you ever locate some amber fender lights for your 3930? If so, what did you find/install?
BarnieTrk
Happy Gilmore, Did you ever locate some amber fender lights for your 3930? If so, what did you find/install? BarnieTrk
I bit the bullet and just bought the OEM light assembly.
   / Ford 95 3930 rear amber lights #5
HG,
Thanks for your follow up reply! :thumbsup:
BarnieTrk :cool2:
1996 International Water Truck with a Caterpillar Engine (A53473)
1996 International...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
Fire Truck (A51692)
Fire Truck (A51692)
2008 Ford F-450 14FT Flatbed Truck (A51691)
2008 Ford F-450...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2020 Genie TZ-34120 (A50123)
2020 Genie...
