Ford Bottom Plow Shin
   / Ford Bottom Plow Shin #1
farmforwildlife
South Carolina
I've been trying to order new shins and shares for a 2 bottom Ford Plow. I ordered both the shins and shares from TSC and the shares fit but the shins didn't. Every reference I have found for available shins gives the same dimensions with references to OEM part numbers 112136, 201344, 251435, and 104428. Here's the catch, I wire brushed the shin I removed to reveal the part number and it is 112137. I just placed an order with Ag Supply but I'm afraid the result is going to be the same. The problem is with the bolt hole alignment. If there are any plow experts out there that can give me some advice or point me in the right direction, I would appreciate it.
   / Ford Bottom Plow Shin #2
What model of Ford plow do you have?
Some Ford plows were made by Oliver (or White) . Some were made by Pittsburg Plow.
There were a few specialty bottoms, which were quite different than "ordinary", but they are fairly rare.
I could be wrong but I've always been under the impression that it is a 3 point Ford 101 2-14 with landing lever. It is definitely a Ford and looks just like a 101 to me.
   / Ford Bottom Plow Shin #4
farmwithjunk i had white ford and case plows that were exactly the same. i always were told that they were made by pittsburg plow.these were big 6 bottom auto reset plows.i always had a problem with the bars cracking .overall i liked them you could plow standing cotton stalks.let me know how to tell a oliver plow or pittsburg plow?
   / Ford Bottom Plow Shin #5
I got my 101 shares and shins from a John Deere dealer. Take a share into a large dealer (Deere, Case, New Holland) and one of them should be able to match up the holes.
See if these measurements are for your plow.
   / Ford Bottom Plow Shin #6
Scroll through this listing and see if you can find any shins that measure the same as yours. It's uncommon, but SOMETIMES people will switch the frog (part all the wear parts attach to) from another brand of plow....
http://www.powellequipmentparts.com/wc-moldboard-plow-parts_opt.pdf
I'm inclined to think that's some sort of Ford bottom though, possibly a deep draft bottom, or a scotch bottom maybe...? Your number (112137) is one off a fairly common Ford part #, (112136) which leads us right back to Ford.
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
JOHN DEERE 7210R LOT NUMBER 270 (A53084)
JOHN DEERE 7210R...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
