Ford garden 16hp 3cyl diesel. aftermarket filters available?
   / Ford garden 16hp 3cyl diesel. aftermarket filters available? #1
cfb
Bronze Member
Cleveland, Ohio
1949 Ford 8N, Ingersoll 448, Ford 16HP Diesel
Hi,
Tractors is about 25 years old. I use 134 hydraulic or transmission fluid which operates forward, reverse and all lift mechanisms. I have two filters for this system, one called a line filter and the other a suction filter. Each, from Ford, costs around $33. I wonder if there are cheaper (in cost) filters available or if you can use a car engine filter if the threads fit? One gets replace every 100 hours, the other 200 hours. thanks . cfb
   / Ford garden 16hp 3cyl diesel. aftermarket filters available? #2
Most auto parts stores can cross over filter part numbers. Have you tried that?
   / Ford garden 16hp 3cyl diesel. aftermarket filters available? #3
thank you friends for replying. I had not thought about asking at an autoparts store. And Todd, thanks for the added help of a web site and even a look up possibility. I guess I was just generally concerned that and auto type filter may not be suitable for a tractor, but I suppose a filter is a filter is a filter, as long as the application is similar.
much appreciated, cfb
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
VENTRAC 4500Z ARTICULATING TRACTOR (A51242)
VENTRAC 4500Z...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52128)
NEVER USED FECON...
DEERE 250 SKID STEER (A51242)
DEERE 250 SKID...
