Ford LGT 14 Glow Plugs
   / Ford LGT 14 Glow Plugs #1
rodgriffith
When I first got this garden tractor I could turn the key backward and the glow plug dash light would come on and preheat the cylinders. Now the glow plug dash light only comes on when the key is turned to the starting position and the engine is turning over. Does anyone know what this could be?
   / Ford LGT 14 Glow Plugs #3
Besides the possibility of a bad switch, it could also be a bad glow plug relay or the wiring to it - that is what comes on when you turn the key backwards. My particular tractor also has a glow plug timer associated with it that when you turn the key backwards it starts the timer that engages the relay for the predetermined amount of time, mine is about 15 or 20 seconds. I think alot of tractors also engage the glow plug relay while in the start position too, mine does, but the light doesn't always come on while in the start mode. It would be wise to try and find the wiring diagram for your tractor to see what components yours actually has.
Thanks for the advice.
2015 ford f350 4x4 mechanic SERVICE TRUCK (A52377)
2015 ford f350 4x4...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2017 FORD F-650 FLATBED DUALLY (A52472)
2017 FORD F-650...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
