Ford model 221 Disk Harrow
   / Ford model 221 Disk Harrow #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
Neighbor was cleaning out his grove and had an older Ford Disc and I think the tag says it is a model 221. (Name plate was pretty beat up). He thought his dad used to pull it with an 8N or 9N but wasn't sure. It is 3PH and measures approx 5' wide with 20" blades. Has the option of allowing the rear gang to float independant of the front by removing two bolts. weather permitting and we get it completely dug out will post a couple of pics.
Questions I have are:
Does any one know if this has ball bearings in it or wear type wooden blocks.
Are the nuts that hold the disk blades on the gangs left or right hand thread? Right front gang is loose.
Any other info on the old disk would be appreciated. I am hoping to use it to level off some of my pasture that I want to turn into yard.
Should give my little BX a work out..
TIA
Roy
AC CHARGING MACHINE (A50854)
AC CHARGING...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
2011 International School Bus (A49461)
2011 International...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2015 FREIGHTLINER...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
