Ford NAA Stabilizer Bar
   / Ford NAA Stabilizer Bar #1
Ortis
Bronze Member
Maryland
I have a 1954 NAA that I am using with a 6' King Kutter finish mower.
I have shortened the chains on the 3-point hitch to limit mower sway.
Questions: How much sway is acceptable? I see that sway bars are sold on some sites. Should they be used? I need new chains anyway so should I buy ones with turnbuckles so they would be more adjustable?
Sure appreciate any advice.
Ortis Evans
   / Ford NAA Stabilizer Bar #2
TSC sells the solid bars for about 8$ each.. plus a under-the-fender bracket kit with 2 brackets for about 8$.. then you need 2 short stubby 3pt pins.. sometimes the brackets come with the stubby pins.
I use them.. I don't like my mower swinging to the side when i make a hard turn. Sometimes that inch or 3 of movement makes the difference of missing or taping out a fence post.. or one of the wifes plants.. etc. Here's a rear pic of my 8n. Setup will be identical for the NAA..
Soundguy
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
NEW Wolverine Skid Steer Vibratory Roller (A53002)
NEW Wolverine Skid...
