Ford/NH 1700 Tractor Starter/Ignition Conundrum
   / Ford/NH 1700 Tractor Starter/Ignition Conundrum #1
crosspike77
Ford New Holland 1700
Hi folks. Ya'll have been helpful in the past, so, here I am.
Ok, lets start with what I did and see how bad I messed up.
Had a bad battery, so replaced the battery. Had a bad ignition switch, replaced. New voltage regulator. Was still having starting issues. Just took a few tries and would eventually kick over until one day it wouldn't. I looked at the starter solenoid and wanted to clean up connections there. Got off the positive lugs, then the negative lug was giving me a little trouble and then started wiggling, so the stud was completely loose. I got that off, then ordered a new solenoid. When the new solenoid arrived I went to put it on and was rushing and my wife wanted to tell me something, so I mistakenly put the alternator (yellow) lead onto the solenoid neg stud and the battery on the positive stud. I then discovered a wire came off the ignition switch and put it where I thought it came off of. Turned the key and smelled burning electrical and saw smoke coming out the starter. I promptly stopped cranking and undid the ignition wire and found my mistake with the alternator wire. After that I placed the alternator wire on the pos stud and then the switch wire in the correct spot. After that I got nothing when I turned the key. At that point I figured I fried the solenoid and the starter due to the smoke. I ordered a new one.
It arrived yesterday and I got the old starter off and placed the new one on. Same result as before. Nothing when I turn the key. I'm guessing I fried the new ignition switch, so I have a new one on order. I can confirm voltage from solenoid to #30 on the switch, but nothing when turn key. Dash light illuminates the speedo, but I might have popped a fuse at the headlights, which is next after work today.
My question is, what else am I missing or could have fried ? Am I on the right track with new ignition switch? Could I have fried the new voltage reg and is affecting start? Do I need to investigate something else and report back?
Any insight would be much appreciated! Also could I have messed something up worse with the alternator wire on the negative stud for that short term?
UPDATE: I switched out with the original Ignition Switch and still the same result. Nothing when I turn the key. I must have blown something else. Is there a fuse inline with the #50 wire or the #30 wire I should look for? Also, I noticed a small silver cube with a wiring harness on the right side mounted on the same bar as the voltage regulator. There is a wire coming off it with a round connector, I may have placed that loose wire on the ignition switch when I was fixing the glow plug loose wire. What is this and where does that wire actually belong? Could I have fried that and that is cause of no ignition?
   / Ford/NH 1700 Tractor Starter/Ignition Conundrum #2
Not sure if it's any help, but my Ford 1210 gave me problems a while back. It acted like a dead spot on the starter. Sometimes a good whack to the starter made it turn over.
The problem was a wire that burned off INSIDE the insulation near the starter.
The starter is new out of the box. I'm not getting response to key turn. I'm leaning toward a bad ignition wire as I check through things. I just discovered a wiring diagram that shows a possible fuse inline with the White #50 wire. Gotta find that next. If that popped. I hope that's it.
   / Ford/NH 1700 Tractor Starter/Ignition Conundrum #4
Have you tried bypassing your ignition switch or running a heavy wire, such as a jumper cable direct from your battery to the positive terminal on your starter? That would at least tell you if the starter is working.
Yes, I bypassed the ignition switch last night with a jumper wire from starter + to the switch lead. Fired right up. Traced the switch wire (white #50) to a relay on the dash bar. Assuming I might have popped the relay, so I have a new one ordered. My query is still, what is the random black wire coming from the relay and where should it be connected, my guess is a ground to the body, but I'm not doing anything till I'm sure.
I've installed a new relay and got all of the fuse block wires in the correct places. The new relay is plastic compared to a metal one. I was hoping for it to fire right up when I turned the key, but still nothing. Can the voltage regulator affect ignition? Also, the starter is brand new, but the placement for the #50 wire is different (which comes from switch to relay, then relay to solenoid). I've emailed the folks I bought the starter from if it's possible there is another place I hook that wire too on the solenoid I am missing.
Next steps taken: I went to the auto parts store with the recently purchased battery. Whatever I did fried the battery, so new battery and cable acquired. Ran a new wire from solenoid to relay and from relay to switch. Still nothing when I turn the key except for the Oil and Battery lights. With the new battery and starter she fires right up when I jump the positive on the solenoid to the #50 wire spot. Solenoid clicks and she fires up. Still wondering if I connect that wire on the relay thats loose to something correct or I fried something else. I am at a loss for what to replace next or what to I need to do.
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
