Ford/NH 1700 Tractor Starter /Ignition Conundrum
   / Ford/NH 1700 Tractor Starter /Ignition Conundrum #1
crosspike77
Ford New Holland 1700
Hi folks. Ya'll have been helpful in the past, so, here I am.
Ok, lets start with what I did and see how bad I messed up.
Had a bad battery, so replaced the battery. Had a bad ignition switch, replaced. New voltage regulator. Was still having starting issues. Just took a few tries and would eventually kick over until one day it wouldn't. I looked at the starter solenoid and wanted to clean up connections there. Got off the positive lugs, then the negative lug was giving me a little trouble and then started wiggling, so the stud was completely loose. I got that off, then ordered a new solenoid. When the new solenoid arrived I went to put it on and was rushing and my wife wanted to tell me something, so I mistakenly put the alternator (yellow) lead onto the solenoid neg stud and the battery on the positive stud. I then discovered a wire came off the ignition switch and put it where I thought it came off of. Turned the key and smelled burning electrical and saw smoke coming out the starter. I promptly stopped cranking and undid the ignition wire and found my mistake with the alternator wire. After that I placed the alternator wire on the pos stud and then the switch wire in the correct spot. After that I got nothing when I turned the key. At that point I figured I fried the solenoid and the starter due to the smoke. I ordered a new one.
It arrived yesterday and I got the old starter off and placed the new one on. Same result as before. Nothing when I turn the key. I'm guessing I fried the new ignition switch, so I have a new one on order. I can confirm voltage from solenoid to #30 on the switch, but nothing when turn key. Dash light illuminates the speedo, but I might have popped a fuse at the headlights, which is next after work today.
My question is, what else am I missing or could have fried ? Am I on the right track with new ignition switch? Could I have fried the new voltage reg and is affecting start? Do I need to investigate something else and report back?
Any insight would be much appreciated! Also could I have messed something up worse with the alternator wire on the negative stud for that short term?
UPDATE: I switched out with the original Ignition Switch and still the same result. Nothing when I turn the key. I must have blown something else. Is there a fuse inline with the #50 wire or the #30 wire I should look for? Also, I noticed a small silver cube with a wiring harness on the right side mounted on the same bar as the voltage regulator. There is a wire coming off it with a round connector, I may have placed that loose wire on the ignition switch when I was fixing the glow plug loose wire. What is this and where does that wire actually belong? Could I have fried that and that is cause of no ignition?
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A52576)
2020 CHEVROLET...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2020 KUBOTA RTV...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
