Ford/Shibaura 2100 Hydraulics Not Working
/ Ford/Shibaura 2100 Hydraulics Not Working #1
Coffs Pete
Australia
Ford 2100
I'm hoping that someone may be able to assist me with a problem I am having with my Ford 2100 4WD tractor. The hydraulics have always been OK for lthe last 4 years, but recently, I have lost all up and down with the 3 Point Linkage. I cleaned the filters and changed the hydraulic oil and everything seemed fine.......slasher up and down, how it should be .....but it only lasted for about 20 mins. Then I lost all lift and even power steering? I left it overnight and the next morning, all seemd OK but again for only 15 mins but this time I didn't lose power steering. I let it stand for 30 mins and started it up and hydraulics lifted the slasher up, but only for 50 secs, and then it slowly descended all the way to the ground. I am at a loss at how to fix it.....I loosened the bolt for the rear filter and only a slow trickle of oil came out, which made me think that maybe the oil filter is clogged up, despite it having been cleaned and soaked in petrol. I was thinking of putting some holes in that filter to see whether the filter, although it appears clean, maybe it is clogged up and not allowing the oil through fast enough? I have not 'bled' the system and I believe that to do that, I loosen the bolt on the return line, near the pump, and allow any air to escape. If you have any suggestions, I would be very grateful. Thanks... Pete
/ Ford/Shibaura 2100 Hydraulics Not Working #3
I'm not positive but I believe my 2110 ford had a sump suction screen under a 3 bolt round cover on the side of the transmission. I think it did but not sure because I also had other similar models at the same time. Check a parts list or owner's manual and if you have one, clean it. Maybe someone else will know for sure.
Thanks Sixdogs and PsRumors, I'll have a look at it this morning and see what develops. I really need the lift so much, as I am on very steep land and need to put as much traction to those rear wheels. I'll let you know what develops. Coffs Pete
Had another go at it today and cleaned the filter.....dirty with metal fragments, and only cleaned about 4 hours of use ago. After cleaning, hydraulics worked for a short time....15 mins....then no more. Decided to 'crack' the return line and spewed oil everywhere, but then the hydraulics worked perfectly for 15 mins, then back to it's old bad habits again. Tried 'cracking' the return line again, but so we didn't lose as much oil and all to no avail. Lost power steering as well on last drive today. Will think about it some more and try again. Thanks for your assisitance...Pete
294 (A52706)
294 (A52706)
Deere 350G LC (A53317)
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
UNUSED FUTURE FT50-(50) 12' PIECES OF GALVALUME (A60432)
UNUSED FUTURE...
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
New Holland WorkMaster 37 (A53317)
New Holland...
