Ford Simms injector pump help.
/ Ford Simms injector pump help. #1
daryng
Gallatin
Ford 5200
I'm finished with my rebuild of my dad's 69 5200. I'm full of fuel, fuel lines are bled, but fuel won't enter the actual injection pump. It's as if the fuel shutoff is stuck in off and not allowing fuel to enter. The hand lift pump pushes fuel just fine, but nothing to the lines running to the injectors. any help would be appreciated.
/ Ford Simms injector pump help. #2
I suspect there are two bleed bolts on the side of the injection pump which need to be bled one at a time using the lift pump and then once that is done, bleed each injector line at the injector end.
Look for bolts with a copper washer under the head.
I dont know your model of tractor but have experience with Simm's pumps of that era
Dave m7040
I've done that. I just can't get the fuel beyond the injector pump. The fuel rack isn't stuck. I'm stumped
/ Ford Simms injector pump help. #4
Remove 1 injectorline and see if fuel is coming out of the pump ? Open the inspectioncover to see if the pumpcrank is turning ? Mybe you forgot to install the idler gear in the drivetraincover ?
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
TAKEUCHI TL6R SKID STEER (A65053)
TAKEUCHI TL6R SKID...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
