Forestry mulching
   / Forestry mulching #1
Bosley21
John Deere 5085e
I have about 3.5 acres that will be clear by forestry mulching that will event be horse pasture. The 3.5 acres consists of mostly pines with a few gum trees through biggest being maybe 12” in diameter. My worry is after the mulching on what to do with the stumps and worry’s of regrowth. Plan is to mulch then burn the pasture area.
   / Forestry mulching #2
Mulching should take the stumps to ground level. So disc up the area and seed with grass and cut regularly. If your concern is horses and holes eventually from the stumps causing issues that may be valid for pulling some of the larger stumps.
   / Forestry mulching #3
I thin my pine stands. You should not get regrowth from the pine stumps. They start from pine cone seeds. I don't know about your gum. If you get regrowth - just go out and hack the young stuff down.
   / Forestry mulching #4
If there's a lot of gum, you could spray to stop the sprouts.
2008 Ford F-450 SD 4WD Pickup Truck (A50860)
2008 Ford F-450 SD...
1997 Chevrolet S10 Ext. Cab Pickup Truck (A48081)
1997 Chevrolet S10...
2015 Ford F-250 4x4 Liftgate Service Truck (A48081)
2015 Ford F-250...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2024 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2024 Ford F-150...
2010 Ford Crown Victoria Sedan (A48082)
2010 Ford Crown...
