Found an old Modern boxblade
   / Found an old Modern boxblade #1
streamin
Conroe, Texas
Mahindra 5035 HST
Came across this on craig's list, not very nice to look at but I think the price tag new would have been several thousand. Took it for $550, no scarifies but just heavy implement that I prefer over the lighter ones.Looking into sandblasting and possibly powder boxblade3.jpgboxblade1.jpgboxblade2.jpgcoating.
   / Found an old Modern boxblade #2
That should cleanup real nice.
   / Found an old Modern boxblade #3
Looks pretty solid - but if you intend to move a lot of dirt, you may decide you need rippers - since most 3ph's don't have power down, you can only get so much action without them.
If you decide in favor of rippers, here's one of the better prices - TSC seems to be 2-3 TIMES as proud of theirs
Box Blade Parts
Good luck... Steve
   / Found an old Modern boxblade #4
Looks like a nice heavy blade, any idea on weight? I am sure you will enjoy it, especially since you saved a lot of money.
John
Thanks for the link, I do plan on getting some rippers. I estimate the weight around 1100 -1200lbs. Good thing about the box blades, they are basically the same used as they are new, can't really were them out, I'm happy about the find.
   / Found an old Modern boxblade #6
That is good weight it should cut really well. What type of retainers do you have to hold in the scarifiers?
John
   / Found an old Modern boxblade #7
Good find:thumbsup:
   / Found an old Modern boxblade #8
John
I suspect it is the V-clips like the Gannon and some others use. If so, it would require the scarifiers with notches in them.
To the OP, congrats on the new box blade. Looks heavy duty and should serve you well.
John
That's a good question. I don't see any type on it, I was trying to find a picture of it new but no luck. Seems to be too old.
   / Found an old Modern boxblade #10
The scarifiers look to be the type on my Atlas box blade, the scarifiers have notches in them that set into the front and then you drop in a 1/2" diameter pin in the rear to hold the notch in place. Pretty simple but I think it weakens the scarifiers and would prefer the type with a hole in the middle that you pin in place. I have actually broken a couple of mine right at the front notch.
Mini Universal Tree Spade (A46502)
Mini Universal...
Hanson 2 Wheel Sprayer Stainless Steel Tank (A46502)
Hanson 2 Wheel...
KC 32in. Mini Skid Steer Root Rake (A49339)
KC 32in. Mini Skid...
1992 Ford Supply Truck (A47307)
1992 Ford Supply...
John Deere WHP36A (A47307)
John Deere WHP36A...
Car Ramps (A49339)
Car Ramps (A49339)
