Found my battery drain - the hard way
   / Found my battery drain - the hard way #1
eightksi
Bronze Member
Cranberry Twp., Pa
198? Satoh Buck S470d
I found out why my battery drains on my S470d....the smaller ground wire that comes off the wire loom next to the starter was kind of pinched between the mesh motor guard by the exhaust, and the clutch bell housing. The vibration from the motor wore off the jacket on that smaller ground wire. Then it was grounding on the tractor. Then, it sparked yesterday!!!!
I pushed the wire loom back a bit, away from the bell housing, and it stopped sparking. Just in time to not catch the thing on fire! That whole wire had its casing rubbed/burnt off. it some how did not damage the wire loom too much...the other wires for the alternator, headlights, etc, didn't get damaged too bad, and it ran fine when I drove it to the garage, and started OK after I let it sit for awhile. Scary, though. I happened to be off the tractor clearing some toys away so I could mow, and came back and saw it sparking and smoking there near the exhaust, and caught it in time before I had a real problem. I was able to get electrical tape over the ground wire and cover it/insulate it with tape pretty good. I bent the mesh cover out a little with a screwdriver to it would pinch and rub the wires anymore....Yikes.
   / Found my battery drain - the hard way #2
Not to get picky, but if it truly was a "ground" wire, it wouldn't 'spark' when touching frame. Gots to be a hot wire for something.
Glad it happened it front of you and not while stored in garage or somewhere. Could of easily flamed up.
   / Found my battery drain - the hard way #3
And it should have blown a fuse before it started sparking. You should double check that you have the proper size fuses for the different circuits.
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
30046 (A53424)
30046 (A53424)
2015 FORD F550 XLT SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XLT...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
Landoll Lowboy Trailer (A55218)
Landoll Lowboy...
