Freak Window Pop or Ghost?
   / Freak Window Pop or Ghost? #1
RedNeckGeek
Super Member
Butte County & Orcutt, California
Kubota M62, Kubota L3240D HST (SOLD!), Kubota RTV900
Yesterday afternoon a loud bang interrupted the peace and quiet, and almost had me diving for cover. It came from the guest room, which has a large glass sliding door on the south wall. When I opened the hall door to look in I could see the fixed pane was crazed from top to bottom, but thankfully there was no bullet hole. What a relief, as I'm a long way from anywhere and don't need that kind of trouble. It's a double pane window, and it was the pane on the inside that broke. It seems to have started half way up on the side of the frame away from the wall, that is in the middle of the door. I'm trying to figure out why it just spontaneously shattered. We had over four inches of rain in the last couple of days; could the slab foundation have settled enough to cause the frame to warp and stress the glass? If so, why just the inside pane? Any idea how much trouble this is gonna be to fix? I've had the slider side replaced before (darn weed whacker), but it's not clear how the fixed pane comes out of the frame?
TIA...
   / Freak Window Pop or Ghost? #2
The glass may come out of the frame to be replaced OR you might have to replace the frame and all. I had a much smaller double pane window that was broken when I bought this place so I took it out and to a glass company and they told me those were not made to be repairable; had to buy the whole thing.
As for why yours broke, I couldn't even guess beyond what you've already said.
   / Freak Window Pop or Ghost? #3
I could think of many reasons why it happened that relate to the building structure or thermal effects. That should be tempered glass, and that stuff is especially sensitive to point loads/impacts.
Is it very abnormal to have that much rain where you are (which I understand is the case for parts of CA right now) ? If so, I think you're on to something with that line of thought. A lot of rain in a normally dry environment could do everything from causing wood framing or trim to swell, to causing soil settling, to even causing soil movement if the soil has any shrink/swell potential. Not sure about the soil out there, but here we have shrink/swell soil in some areas, and excessive moisture will cause it to swell. That can jack foundations and wreak all sorts of havoc.
Maybe take a look at the foundation near the slider that cracked, or look for obvious shifts/changes in the wood framing and trim nearby.
Be curious to know what you discover!
   / Freak Window Pop or Ghost? #4
There was a story on morning TV yeaterday that said that there are many glass items breaking due to inclusions in the glass during manufacturing.
Good luck figuring it out.
   / Freak Window Pop or Ghost? #5
I'm gonna go with your ghost theory. That's probably what your homeowner's insurance will tell you when you try to get them to fix it.
   / Freak Window Pop or Ghost? #6
You're avatar is way cool! I am sitting here with a cat right now. Doesn't look as happy as that guy!
   / Freak Window Pop or Ghost? #7
I'd go with ghost also, it just sounds better.
   / Freak Window Pop or Ghost? #8
A very tiny meteorite, sonic boom just before it hit the glass. :D
It seems like the glass itself shattering but still in the frame wouldn't make that loud of a noise. I would guess the noise was something structural in the house around that doorway giving way or shifting after being under stress.
We had some 8x8 eastern hemlock posts in our old house that would make a sound like a gunshot as they dried out and checked. From that I know things can make some unbelievable noises you wouldn't think possible.
   / Freak Window Pop or Ghost? #9
I've had that happen a couple times. Every time there was a dead bird on the ground under the window.
   / Freak Window Pop or Ghost? #10
I had a garage Window broke and took out the rear door window of my Silverado pickup,all there was left was partridge feathers.The Bird must have went back out of broken Window.
Carnival Ticket Booth (A51691)
Carnival Ticket...
2020 Isuzu NPR Heil 8RLDB 8CuYd Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
