DavidBradley
- Joined
- Jun 23, 2004
- Messages
- 41
OK I bought a Farm Pro 2420 at a Homier Road Show, never owned or used a tractor period. When you stop laughing, if you have the time, please answer a couple hundred questions. I plan to start a thread on this tractor for others thinking of buying to read and decide.
(1) There is a small oil (?) leak coming from the steering wheel. (Please don't laugh) When I bought the tractor, I supposed this to be from someone filling the whatever it is box under the wheel too full. Apparently not. I cleaned it off, drove the tractor around a bit, and the oil was back. The four bolts holding the cover on where the steering column goes into the box were loose (one is missing a lock washer), I have been able to tighten two of them, the other two will require removing stuff, to get to with a wrench or socket. Will someone tell me what this box is and is there a method of tightening these bolts without removing the fuel tank and support shelf. There are access holes for the bolts in the support shelf, but the tank sits in a place that makes them useless. The manual states that this setup is Type II steering box.
(2)In the fuse block there are two rows of fuse holders, 5 on top, and 5 on the bottom. On the bottom row on the right, looking at it from the front of the tractor, is NOT a fuse, but a piece of #12 wire which if removed will not allow the engine to crank, and kills all the power to the gauges. What size is this fuse supposed to be.
(3)On the top row of the fuse block are 4 fuses starting from the left to the right. (from the front of the tractor) the 5th slot is empty. Is there supposed to be a fuse there, if so what is it for and what size is it. I ask these questions about the fuses, because I have not found the answers in the manual, And could not contact customer service at Homier today. I have talked to them before and they did answer many questions I had before I bought. But not today.
(4)Some of the gauges have a wire that is not connected to anything (just hanging loose). Is this supposed to be. The gauges work, but I wonder what the loose wire is ( a light maybe?) and where to connect it.
(5) Not a question. The tractor seems to run fine, (to me anyway), and I used the Farm Pro 5' finish mower to mow about 1 acre. It too preformed very well. I will change the zerks on tractor and mower out for better ones, and do the recomdened PM I have read on this forum before I put much time on it. The tractor was bought new with 5hrs now has 6.5.
Thanks in Advance for Your Help
Dave
Dave
