From tractors to golf carts
   / From tractors to golf carts #1
The Dougster
Lampasas, Tx
Kubota L2800
Yup... I bought a used golf cart (electric) to park next to my 'Bota and sure enough, I have a problem... Apparently, the cart had just enough charge on it to test drive for the next sucker that comes along... well, I was that sucker and didn't spend enough time checking out the cart... The darn thing won't charge up... better described, it won't hold a charge.... Checking it out, I discover the batteries cells are bone dry... My questions are: Will adding water to the cells bring the batteries back to life? Each battery, there are six of them, have four portals on top for checking/adding water... does this mean they are eight volt batteries?
As you might have imagined, I am clueless when it comes to golf carts.. lol
   / From tractors to golf carts #2
In general, no. However, it depends on the amount of lead sulfate that has settled in the bottom, and maybe shorting the grids. I have heard that some people have dumped out the contents, washed out most or all of the lead sulfate, and put acid back in, and water, and it helped somewhat. A set of batteries now days will run about $425 to $600. If they have only been dry for a little while, maybe. I would try and slow charge them for a couple of days, and just see what happens. Clean all the terminals real good, and use distilled water. Good Luck .
As far as the required voltage, look on the charger label .
   / From tractors to golf carts #3
The Dougster I,m not sure on the 4 fill holes . But everyone I ever seen takes 6 , 6volt batterys which makes it a 36V system & takes the correct type charger .
We have an old Harley Davidson cart & I do have to add water every so often beause frequent charging tends to boilt the water out of them , But I,ve never had them run dry, I,d say theres a good chance if there the correct batterys ( deep cycle ) theres a good chance refilling them with distilled water ( thats what I was allways told to use ) & with a good charge They might just come back to life . I hope that helps , Best of luck Because Them batterys aint cheap :eek: . Bob
   / From tractors to golf carts #4
Don't know if you bought from an individual or a dealer and how long ago. If from a reputable dealer you might be able to get some help. If you've not had it long enough to boil the water out then the dealer didn't service the cart properly before delivery to you. Of course the owner who the dealer got it from may not have maintained it properly either. From experience with my cart it would take a long time and a lot of charging to leave the cells as low as you describe. Mine is relatively new (came from a country club) and the special charger that came with it interacts with the cart computer control to assure proper charging - not a typical battery charger. My dealer could tell me the age of both the cart and if the batteries were original or had been replaced and when. If the batteries are 5-6 years old it would probably be worthwhile going ahead and spend the money for a new set. Of course no money lost trying to refill and do an extended slow charge to see if you can bring them back to life.
   / From tractors to golf carts #6
You have a 48 volt golf cart with six 8 volt batteries. Go ahead and top off the batteries with water and charge them. What do you have to lose? It is not unusual for the water line to drop below the top of the cells in golf carts because you normally charge them a few times a week. My water level frequently gets low and I refill and recharge and the cart runs fairly normally.
I have 2 old 36 volt carts. In my newest one I put 3 12 volt batteries out of my trucks when I put new batteries in my trucks. It is 250 pounds lighter, much faster, charges much faster and needs recharging twice as often.
When they go bad I am going to get 3 new 12v Walmart batteries that have the 3 year replacement guarantee. Most cart batteries only have a 1 year guarantee.
I knew I could count on you guys to be of help... The cart will be used at the ranch and only on weekends for relatively short periods... To be honest with you, I really, really hate to sink several hundred more dollars into this thing but that's another story for another time...
Next weekend will be the next time I will have an opportunity to put the charger back on and see if adding water has been helpful.. we'll see, we'll see...
Tallyho, it sounds like you are speaking my language..... Last week, while cooling my heels at Wal Mart getting a tire mounted, I happened to be looking at the batteries and noticed that WM has a 12-volt deep cycle marine battery for $75... 3 X $75= $225, American.... a lot of money for sure but that beats the heck out of the $600 someone suggested... When it comes to being a cheepskate, I'm near the top of the list. lol Again, thanks a lot.
   / From tractors to golf carts #8
I believe your cart is 48 volts and will need 4 12 volt batteries.
   / From tractors to golf carts #9
I would also use distilled water!
Tallyho wrote:
<"I believe your cart is 48 volts and will need 4 12 volt batteries.">
Yessir, I knew that but was thinking "cheep"... again, I appreciate your input..
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
2021 Allmand Bros Maxi-Lite II S/A Towable Light Tower (A52377)
2021 Allmand Bros...
KUBOTA L2501 TRACTOR (A54756)
KUBOTA L2501...
2006 FONTAINE TRAILER CO. 48X102 FLATBED SPREAD AXLE (A53843)
2006 FONTAINE...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
