front axle lube change
   / front axle lube change #1
jb112454
Prague OK
2001 Kioti DK35
when changing the lube in the front axle on my dk35 it took about 2 hours to get all the gear oil out. the reason for this is the drain holes are small. even with the filler plugs removed it still took 2 hours. it was warmed up too. good thing you don't have to change it often but when you do get it going first so you can do something else while its draining.
JB
   / front axle lube change #2
thanks for the tip. is there a second plug so air can enter?
James "woody" Mills
yea but i had it off and it didn't make any difference.
JB
   / front axle lube change #4
You could lightly pressurize it with an air compressor. Not too much though, it would be bad to have to replace seals just to save an hour or 2.
i might try pressurizing it next time. thanks
JB
FMC B-601 Brake Lathe (A49339)
FMC B-601 Brake...
2012 (A49339)
2012 (A49339)
1600 (A49339)
1600 (A49339)
3150 (A46502)
3150 (A46502)
John Deere 7810 MFWD Tractor (A46502)
John Deere 7810...
2017 Ditch Witch Walk-Behind Trencher (A46683)
2017 Ditch Witch...
