front main seal leaking on a LA
   / front main seal leaking on a LA #1
Uncle Wayne
Moulton, Alabama (Lawrence County)
4320 John Deere
I'm shopping around for a LA John Deere and found a good one nearby but there is oil pouring from the front main seal. Oil pressure is good while running but the leak is bad. Knowing nothing about that, is that a costly repair?
After we took the radiator cover off and the cover that goes underneath the engine we found the front main seal was not leaking. The corner bolt that held the oil pan on was stripped and was letting the oil pour out. The hole was re-tapped and the oil leak stopped to almost nothing.
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2012 Ford Explorer (A50123)
2012 Ford Explorer...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
