Front mount Kubota snow blower chute
   / Front mount Kubota snow blower chute #1
Edhof
Michigan\'s U.P.
Kubota B2710
The hollow portion of the worm gear's shaft failed and the chute is inoperative. Poor design caused the faulure. There is no absorbing stop limit when rotating the chute in either direction. The worm gear simply reaches the end of the cogs on the horrizontal chute gear, and abruptly stops with no place to go. The stopping damages both the worm gear and the chute gear at the rotations left and right limits. The strain on the hollow shaft of the worm gear eventually fails. I must assume there is a modification to provide a cushioned stop for the chute rotation to eliminate the costly replacement of the worm gear every year or two. Is anybody aware of the modification?
   / Front mount Kubota snow blower chute #2
My blower is new this year and it has a hyd. motor instead of the worm gear. Might be able to retro-fit it to your set up. I would check with your dealer.
   / Front mount Kubota snow blower chute #3
We haven't had any trouble there, is yours electric or manual rotation?
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A51572)
2016 Hino 195h...
New/Unused 66in Quick Attach Rock Bucket (A51573)
New/Unused 66in...
Industrial Air Contractor Air Compressor (A51573)
Industrial Air...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
