BufordBoone
Platinum Member
I have a JD 2355 that came with the farm. The tractor is 1993 vintage and low hours (1,443). I believe the tires are original. I already had to replace one rear tire due to dry-rot.
I now have a flat front tire. This tire probably fell victim to a stob while bushhogging last weekend. The front tires are Firestone 7.5-16 F2.
This tire is tubed. The sidewall showed cracks (visible when flat) that make me think it won't work without a tube. At the very least, I'll need a new tube as the stem on this one shows cracks and rot.
A tire dealer (first call, I've not researched prices much) advised that a new Firestone tire would be about $185. He then said a good (in his mind) alternative would be a used steel belted truck tire. He said the only downside would be less steering ability as the truck tire would not have the three ribs of the F2. He explained that the F2 has a center rib that is higher than the other ribs and that aids in turning.
Has anybody else tried a used truck tire for the front of your tractor? Any positives or negatives?
I may just put a new tube in my current tire but I've got a lot of stobs to worry about. Slime in my ATV tires seemed to cure the stob problem there. The other front tire on this tractor is tubeless and I'm considering it may be cheaper in the long run to replace the bad tire and run slime in both.
Thanks for any help you can give.
