Tires Front Tire Replacement
   / Front Tire Replacement #1
Txrancher224
Millican, Texas
MF 451
Need to replace front tires on my 451. It has 6.00X16s and would like to put 7.50X16 to give more support for the loader. Can I put them on the same rims?
   / Front Tire Replacement #2
I would not guarantee that you can, but i think you should be able to. Look around on the rims and see if you can find anything stamped on the rim. I replaced 6.00 16 on may 730 jd with 7.50 16 tires and used the same rims. Do you have a good honest tire guy handy, cause he would probably know for sure.
   / Front Tire Replacement #3
You should be able to. The 16 refers to the rim size, so any reasonably close 16" tire should fit. The 6.00/7.50 refers to the distance from the tire bead, down across the tread, and back up to the other bead. Of course the 7.50 being the larger number, that tire will be bigger.
There are charts indicating which width rims should be used with with each tire size.
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
AC CHARGING MACHINE (A50854)
AC CHARGING...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
