Front Tires Toed Out
   / Front Tires Toed Out #1
bobb g
Michiagn
Craftsman DGS6500
I have a model 917.287462 (DGS6500) and while cutting the lawn on Saturday, I went to make a right turn and the tires toed out by a lot. I noticed the last cutting the left tire pointing a bit left, while the right tire was failrly straight. I also noticed the steering wheel no longer being centered...made me think of a bad alignment job.
After inspection, I noticed both the right and left spindles that go though the tube on the axle were not seated properly. There was a ton of play in the tires. I removed the red grease cap and found some sort of plastic sleeve cracked in half vertically, and also cracked horizontally. Found this on both sides. The mover was purchased in 2007, so they are originla parts.
I reviewed the parts diagram for steering and don't see any sleeve per se. Anybody know what I might be looking at? I'm not sure if the the thrust harden bearing...or something like that.
After going around and around with Sears parts, I've decided to call a tech out. It appears that nobody at Sears has a clue as to what I'm referring to, even after providing a picture. I know it's a simple fix, but without the correct parts, difficult to do. Oh well...the grass will need cutting at some point...once the heat departs and the grass decides to grow again.
Sears came out today. Need a new axle and right spindle. The hole wore out....oblonged. Tried to tell me it was due to not greasing it. Told him think again...I'm religious about greasing twice a year.
   / Front Tires Toed Out #4
just read this, maybe this will help someone else out, saved this several years ago.
front axle kinpin bushings # 406013 $2.16 sears
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
2020 KUBOTA RTV...
Ammco Brake Machine (A53424)
Ammco Brake...
